kjd2002 Posted May 24, 2008 Posted May 24, 2008 Iv'e got a genesis valient panel and am just woundering what the 'E' means in the top right hand corner of the screen. Thanks, Kev.
kjd2002 Posted May 24, 2008 Author Posted May 24, 2008 How do I get out of it. I think I've defaulted the panel so it should be reset to the factory code. Thanks, Kev.
ian.cant Posted May 25, 2008 Posted May 25, 2008 How do I get out of it. I think I've defaulted the panel so it should be reset to the factory code. Thanks, Kev. Its been a long time since i seen one, over ten years, but if my memory is working correctly today, eng code then escape.
mjw Posted May 25, 2008 Posted May 25, 2008 Its been a long time since i seen one, over ten years, but if my memory is working correctly today, eng code then escape. its based on the old castle omega 5 isnt it?????...mind you havent used one for about 16 years
ian.cant Posted May 25, 2008 Posted May 25, 2008 its based on the old castle omega 5 isnt it Hell no, its more like an early Galaxy (which it isnt). There was a version of the Omega5 that Securicor had badged up for them but that was an Omege5. The Genesis 1000 was a monster, there was also a mini version called 500 which was similar, smaller, a smaller capacity version and all in one, whereas the 1000 had cards in it.
