Dvr
:huh: Im new here, I have Xvision DVR Model: X16DVR, Installed already by another Company which no longer there.
Problem I need to Use SPOT monitor to split six cameras and main monitor keep the rest of cameras.
Any one can assists me and dont have manuals
Thanks.
Erasto.
erastosebastian@hotmail.com
Thanks.
Erasto.
Hi Erasto
Peter from Xvision here, the X16DVR has a soit monitor output, this will display a single camera or switch through them, the main output will give you split screen views.
To achieve what you desire there are a few options:
i) Split the main output using a T piece BNC Adaptor, this will give you the same view on both monitors
ii) Use a quad or multiplexer to get split scree views on your second monitor
If you need further info please PM me, the above equipment should be available from your local distributor.
Best regards
Peter
