ilkie Posted June 1, 2008 Share Posted June 1, 2008 Should be ok, distance is one to watch though. I was under the impression you should be fitting LSF (or LS0H) sheathed cable for all internal applications. Otherwise you could be liable in the event of a fire. (Fire regs) Ilkie Link to comment Share on other sites More sharing options...
james.wilson Posted June 1, 2008 Share Posted June 1, 2008 There are some sites its mandatory but its not required everywhere yet. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
ilkie Posted June 1, 2008 Share Posted June 1, 2008 There are some sites its mandatory but its not required everywhere yet. Do you mean that the Alarm standard bodies allow the use of cables that produce toxic fumes when burnt? Ilkie Link to comment Share on other sites More sharing options...
james.wilson Posted June 1, 2008 Share Posted June 1, 2008 nicely led but its the wiring regs (7671) not alarm regs and yes they do, much like other things in a building that do. Anyone know if a smoke head is lsf, or a sounder or an emergency light, or any light fitting, socket etc etc securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
leesutton Posted June 1, 2008 Share Posted June 1, 2008 The northern computers cable can be run longer than any other cable on there systems and if you use there spec of cable and you have a problem with your system they will send out the tech guys to have a look but if you use other spec of cable they dont want to know. lee  Lee Sutton E-Mail: leesutton@centurianfire.co.uk Website: www.centurianfire.co.uk Phone: 0845 094 9870 CENTURIAN FIRE & SECURITY (part of centurian group limited) Link to comment Share on other sites More sharing options...
Cubit Posted June 1, 2008 Share Posted June 1, 2008 The northern computers cable can be run longer than any other cable on there systems and if you use there spec of cable and you have a problem with your system they will send out the tech guys to have a look but if you use other spec of cable they dont want to know.lee Yeah, right. But as i said, it's the same with all manufacturers, if you go against their advice, your problem. Not theirs. Link to comment Share on other sites More sharing options...
leesutton Posted June 2, 2008 Share Posted June 2, 2008 Yeah, right. But as i said, it's the same with all manufacturers, if you go against their advice, your problem. Not theirs. I did an installation with 30 doors in warwick used all the specked cable and we had a problem and robin from northern came out as we exhausted all what we could do over the phone and he traced it back to a bug in the software and a faulty reader board, respect to northern as they did come to site but i dont know the procedure since the honeywell takeover. lee  Lee Sutton E-Mail: leesutton@centurianfire.co.uk Website: www.centurianfire.co.uk Phone: 0845 094 9870 CENTURIAN FIRE & SECURITY (part of centurian group limited) Link to comment Share on other sites More sharing options...
Cubit Posted June 2, 2008 Share Posted June 2, 2008 I did an installation with 30 doors in warwick used all the specked cable and we had a problem and robin from northern came out as we exhausted all what we could do over the phone and he traced it back to a bug in the software and a faulty reader board, respect to northern as they did come to site but i dont know the procedure since the honeywell takeover.lee Bet that came as a total surprise to them. Link to comment Share on other sites More sharing options...
daubs8 Posted June 9, 2008 Author Share Posted June 9, 2008 Just to clarify. The supplier only recommends the purple 'tube' as a 'one cable run' solution and nothing else. So it's belden it is in future! Link to comment Share on other sites More sharing options...
sjonley Posted June 9, 2008 Share Posted June 9, 2008 As far as I am aware, CAT5 or any of the category data cables that is a colour other than white or grey is LSF (Low Smoke and Fume) or LSZH/LS0H (Low Smoke and Zero Halogen). These types of cables are usually installed where people work or possible contact with people. The colour of the sheath has no effect on the transmission path of data. The reason why LSF or LSZH is used is that in the case of a fire, the shealth does not give off deadly fumes when burning. With regard to using CAT5, CAT6 against Belden 8723, take a look at a few differences. CAT5, CAT6 (4 pair twisted. Unshielded Twisted Pair - UTP). Normally a box of CAT5 is between Kind regards Stuart Onley SAMS Consultancy Independent Security Consultants email:enquiries@samsconsultancy.co.uk website:www.samsconsultancy.co.uk Link to comment Share on other sites More sharing options...
