Galaxy Remote Servicing
Need a bit of help with this one :(
While using the honeywell RSS the answer phone defeat option will not work if the BT line has the answering service.
The panel will connect if we program the "No of Rings" option to 5 but will not connect if left a the 15 rings ans phone defeat default, the plan is to use UDL to check the system so asking the customer to change the default value is not going to be a option.
Anyone had any luck using the RSS with bt answer?
program the b key to dial out then get the customer to force the panel to call you....
or fit emizon/webwayone and use the transparent ports to do UDL
TSS
Communication is "A question asked, and an Opinion given." I offer mine to help you with yours.
Statements I make are my personal views only at the time they are posted, if I offend you sorry, must be taken in context and do not neccesarily represent those of my employer.
the panel needs to be set to ans defeat as well as rss, then it will work. The idea of ans defeat is that when you make the phone ring once, that primes the panel, then it answers the next call, so you ring it once then hang up, then press it again and it answers before the bt one
Yep thats the way I understood the system to work, but unfortunately the g2 panels just wont work :( Finally got galaxy tech support to confirm that the RSS definitely wont work on a Bt 1571 enabled line :(
Guest RJBsec
I have no issues with any G2's working with answer defeat, however if answer 1571 kicks in immediately or after say 2 rings then you will obviously get issues.
Edit - I'm not using RSS for G2's, rather keeping with AccessLite, maybe it's RSS that's causing the issue.
Quick Fix
Although honeywell said RSS wont work with 1571 enabled, if you change the timeout period in the comms server options to 20 sec from the default 10 sec it will connect to the panel :)
cheers for the help
