Sd1+ Repair's ?
dunt
hi all,
in the past few years servicing i have come across ALOT of faulty sd1+ auto-dialer's mostly with the same fault every time, very faint sounds & display and crashes on test call... happens mainly in rural areas were there is a transformer near by, suspect cause power surges ? who knows.
but but but is anybody having the same problems ?
and is there any way to repair the faulty dialer ?
we have a shelf full of them out of warranty.
thanks in advance davy.
Was at 1 yesterday (Tues ) and all was ok we are in Fife Scotland.
www.AllanMoncrieffAlarms.com
i've not used that many of them, about 30 or so over time, can't say i've ever had any problems.
these days use gartec panels where VoCom is built-in or thr texecom unit, imo superb bit of kit if a tad more pricey.
regs
alan
we have around 400 fitted, and its not nice when you have to hit the customer with a heafty bill for replacing a faulty unit :(
fitted a phew and the only problems i have had is when the customer has changed line over to broad band
so put in line adsl filter all good again
and the only problem with line was when a previouse engineer had fitted one and wire the phone line in alarm cable causing it to crackle
re wired with solid cable no probs
i mainly find them faulty on routine annuel services, but the odd time we would get a call to say the alarm went off but didn't call anyone ? on the call-out its normally a faulty unit, with the same old problem faint display and faint tones/sounds also crashing totally on the test call.
any system with broad band would have a hard wired ADSL filter fitted at annual service.
i service full time between 35-45 services a week year in, year out, and on average replace 2 a month at this rate, granted not all systems have a dialer connected.
when i break the bad news to the customer some times i get the impression that they think I'm trying to pull the wool over there eyes for a few extra quid, so its now time to try and find away to repair faulty units on the test bench.
I've had some appear faulty when broadband has been fitted (switch over to pulse dialing) but if you disconnect them, and leave them for a while you can re connect with a filter , reprogram and most of them come back to life...
TSS
Communication is "A question asked, and an Opinion given." I offer mine to help you with yours.
Statements I make are my personal views only at the time they are posted, if I offend you sorry, must be taken in context and do not neccesarily represent those of my employer.
