Geovision Ver 8.12
recent installed system with remote monitor fed direct fromPC card video out
it is now not working, cable fine,moniter fine
cannot find any info in manual regarding video out,
is there a default in the config programme to enable/disable?
thanks
Graham :rolleyes:
have you tried bring the monito clse to the computer using a known good leaad?
i you'd have to uninstal and delete the directory and reinstal, which will mean losing all the camera names, settings and previous recordings unless you back them up prior.
is the card in the pc working properly though or is it the driver for it duffing it up? might even have the resolution set wrong for the monitor as strange things happen sometimes
regs
alan.
