djandysp Posted June 5, 2008 Posted June 5, 2008 Ello all, jusrt wondered if anybody knew where we can source ID Biscuit powered joint boxes from, although we now use eol weve still got a hell of a lot of castle ID systems out there and ADE dont make the joint boxes anymore and im running out of solder lol
arfur mo Posted June 5, 2008 Posted June 5, 2008 Ello all, jusrt wondered if anybody knew where we can source ID Biscuit powered joint boxes from, although we now use eol weve still got a hell of a lot of castle ID systems out there and ADE dont make the joint boxes anymore and im running out of solder lol might be worth giving gardtec a call, they offer iD systems via an expander module. regs alan If you think education is difficult, try being stupid!!!!
james.wilson Posted June 5, 2008 Posted June 5, 2008 Dantech make a mini t relay in an 8 way jb, might be an alternative, we have used these on old euros and 25's when issues on roller doors, door loops etc. James securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
arfur mo Posted June 6, 2008 Posted June 6, 2008 i never actually used the j/b's, simply wired the biscuit's into standard ones. recently i've been using the G3 8 way j/b's from Gardtec even though G3 is not needed as they have decent terminal blocks in and a tamper button worked by a spring, i think made by Knight Plastics. makes the whole job a lot easier and quicker but they are marginally larger. not seen a square version but most likely they do one or use a 24 way as i do. regs alan If you think education is difficult, try being stupid!!!!
djandysp Posted June 6, 2008 Author Posted June 6, 2008 i never actually used the j/b's, simply wired the biscuit's into standard ones.recently i've been using the G3 8 way j/b's from Gardtec even though G3 is not needed as they have decent terminal blocks in and a tamper button worked by a spring, i think made by Knight Plastics. makes the whole job a lot easier and quicker but they are marginally larger. not seen a square version but most likely they do one or use a 24 way as i do. regs alan Thats what weve been using however problem is they arent powered like the old ADE ones, beleive it or not they do make a difference on longer runs with multiple devices. Sod it, just have to start upgrading the older systems lol
Guest RJBsec Posted June 6, 2008 Posted June 6, 2008 just have to start upgrading the older systems lol Yep, there's a limit to how much you can do to keep things struggling on at your own inconvenience.
arfur mo Posted June 7, 2008 Posted June 7, 2008 Yep, there's a limit to how much you can do to keep things struggling on at your own inconvenience. thats a defo you married - or was i liked the phrase regs alan If you think education is difficult, try being stupid!!!!
