erk108 Posted June 6, 2008 Posted June 6, 2008 i am installing the 9651 panel and using the FSL wiring to detectors.The problem i have is that i want to use the 8 zones on the panel and use the PA connection on keypad for panic alarm button.I cant get this to work even with the link disconnected on the keypad across the PA terminals the panic alarm is not registering.Do i have to enable PA on keypad through programming but cant see how.Can anyone please help.Dont really want to program one of the zones as PA if i can help it.Thanks.
DanB70 Posted June 7, 2008 Posted June 7, 2008 Never had this prob before, have you addressed the keypad with the jumper ?
Alarm Co Posted June 7, 2008 Posted June 7, 2008 i take it you are on about pa on keypad using two of the numbers 1 and 3 or 7 and 9 there is a comand in programing you have to enable for this to work is it 87 ??? from installer mode
erk108 Posted June 7, 2008 Author Posted June 7, 2008 yes 87 enables pa on keys one and three i am not having trouble enabling 1 and 3 as panic alarm that works fine .Problem is there are connections on keypad for external PA to be fitted labelled PA cant get that to work.I dont want to program a zone for PA i want to use the PA connection on keypad but wont work.is it possible to use this connection on keypad for external panic button?
Alarm Co Posted June 7, 2008 Posted June 7, 2008 i am not having trouble enabling 1 and 3 as panic alarm that works fine .Problem is there are connections on keypad for external PA to be fitted labelled PA cant get that to work.I dont want to program a zone for PA i want to use the PA connection on keypad but wont work.is it possible to use this connection on keypad for external panic button? what keypad is 9930?? because only other terminals markd e/t are for external terminate button ??
Guest RJBsec Posted June 7, 2008 Posted June 7, 2008 9440/1 keypad has PA & ET terminals but not using Scantronic I can't offer any further help!
Guest anguscanplay Posted June 7, 2008 Posted June 7, 2008 IIRC from the last time this question was asked - you have to enable 1+3 on the keypad and enable audible panic ...... if your sure you`ve got that right and you havnt got a test meter its worth connecting the panic to a zone on the panel to test the actual button works
erk108 Posted June 8, 2008 Author Posted June 8, 2008 IIRC from the last time this question was asked -you have to enable 1+3 on the keypad and enable audible panic ...... if your sure you`ve got that right and you havnt got a test meter its worth connecting the panic to a zone on the panel to test the actual button works the keypad i am using is the 09943EN which has both Panic I/P and ET terminals on the keypad circuit board.ET terminals were shorted took short off and this is working says tamper keypad on display.Panic I/P terminals are shorted too took short off nothing happens.page 17 fig 11 of manual shows you can connect external PA to keypad.Do i have to connect a panic button to test or just shorting and unshorting terminals should test connection on PA.
