Guest Martyn B Posted May 23, 2004 Posted May 23, 2004 I'm trying to change my user code on the Veritas R8 panel. I followed the user instructions but it didn't work. I've got 2 entry panels, one at the front door, one at the rear. Will this make a difference, and if so, what else do I have to do? Many thanks in anticipation. Martyn B
Deltaseven Posted May 23, 2004 Posted May 23, 2004 The number of keypads should make no difference - its the software of the main panel which determines the programming. On most Veritas panels, enter your code, then press PROG( listen for a ding-dong sound), then 60, new code, prog (ding-dong), reset. If when you press PROG the first time, you get a buzz instead of a ding-dong, then press the 0 button twice - you should then hear the ding-dong. Then press 01, new code, PROG (ding-dong), reset. This applies to older panels. Hope that all makes sense... D7
Guest Martyn B Posted May 23, 2004 Posted May 23, 2004 Thanks D7 That worked fine. Hadn't realised the age of the system made a difference. My manual is post '99 (obtained from the web) but my system is pre '99. Feel more secure now. Martyn
FASTCAR Posted May 23, 2004 Posted May 23, 2004 Both old and new instructions are available on the FAQ page at theTexecom website.
DGMarsden Posted May 23, 2004 Posted May 23, 2004 Tech instructions are also available from <EDITED> for the texecom range.
