Service Engineer Posted June 11, 2008 Posted June 11, 2008 Quote One other thing my friend has a gardtec eurosec cp8l panel and believe it or not tonight every so often it comes up with the bat/fuse check displaying i have the engineer code and just need to tell someone how to change the default border levels between the highest and lowest battery peak levels as they are about 2 hours drive away from meI don't think this option is available on the CP8L.? ........................................................ Dave Partridge (Romec Service Engineer)
jackbuchan Posted June 11, 2008 Posted June 11, 2008 Service Engineer said: Deliberately a blank page at the moment..I don't think this option is available on the CP8L.? sorry not sure what you mean? they are not available can you tell me how i would change them! Because i asked an engineer before about this and they said no problem its the battery levels you need to change! But i had said i would look up the manual but i cannot now find it ! Anything you could do for me m8? Kind Regards, Jack Buchan JDB Solutions Web: www.jdbsolutions.co.uk E-Mail: jack@jdbsolutions.co.uk
james.wilson Posted June 11, 2008 Posted June 11, 2008 jack can you start a new topic for your risco query. Ta James securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Service Engineer Posted June 11, 2008 Author Posted June 11, 2008 Quote What Was The Name Of the Company who created it for you The Website CMS is Site Dynamic, have a look here: http://www.codedynamic.com/ Quote sorry not sure what you mean? they are not available can you tell me how i would change them! I mean There isn't an option on the CP8L to alter the battery monitored ranges. Or there wasn't when I fitted my last one several years ago. Hopefully someone more familiar with recent versions can deny/confirm this.? ........................................................ Dave Partridge (Romec Service Engineer)
alterEGO Posted June 11, 2008 Posted June 11, 2008 As dave stated, it can't be changed on a cp8l. It can be a bit tricky as that message shows up fo a few faults that have nothing to do with battery or fuses.
jackbuchan Posted June 11, 2008 Posted June 11, 2008 alterEGO said: As dave stated, it can't be changed on a cp8l. It can be a bit tricky as that message shows up fo a few faults that have nothing to do with battery or fuses. What could this message possibly mean then? Kind Regards, Jack Buchan JDB Solutions Web: www.jdbsolutions.co.uk E-Mail: jack@jdbsolutions.co.uk
arfur mo Posted June 12, 2008 Posted June 12, 2008 Service Engineer said: I don't think this option is available on the CP8L.? this is a common fault on Gardtec Panels, often caused by the battery in-line fuse springs being a bit shortr/weak, just needs dismantling and stretching to fix it so depends how good your mate is with tools. needs to be vety careful he don't get a shock or touches the boared bare ends touching on anything and blowing the panel, so pia it might be, but go back yourself is best advice. regs alan If you think education is difficult, try being stupid!!!!
arfur mo Posted June 12, 2008 Posted June 12, 2008 jackbuchan said: sorry not sure what you mean? they are not available can you tell me how i would change them!Because i asked an engineer before about this and they said no problem its the battery levels you need to change! But i had said i would look up the manual but i cannot now find it ! Anything you could do for me m8? the info is not in the manual. if anywhere you access it via engineer mode and go to diagnostics near the end, but i don't know on this panel if it can be changed as never tried. see post about fuse holder, you might just have had a flat battery, did you buy new if so might have been on the shelf a while. if you used an old one - that was a false economy. so might take 24+ hours to charge fully if battery is not tired and so the message to stop wait before you get into the 'techy' stuff as that bit is not as easy at it could be a novice, and its there for a reason. reg alan If you think education is difficult, try being stupid!!!!
arfur mo Posted June 12, 2008 Posted June 12, 2008 jackbuchan said: What could this message possibly mean then? off charge volts low, on charge volts low/high names just a few regs alan If you think education is difficult, try being stupid!!!!
kka Posted June 12, 2008 Posted June 12, 2008 option is not available on the cp8l, but is on the cpx Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
