E.o.l Wiring Texecom Vetrus R8+
LED
Can any one tell me if the Prestige PIRs can be used with this panel as the panel states 33 and 10 E.O.L resisitors, but the PIR doesn't it has 2.2 , 4.7 and other figures, but not the R8+ pannel it has the numbers as above.
cheers for any help
first question do you understand what EOL means? if so then you will understand that any pir, can be any value eol. Eol has nothing to do with the pir...but the value of resistor that the panel see in certain conditions :)
Yes I do understand, so I would have to physically wire the correct values within the PIR to make it work.
LED
Kevin..I think he means the pirs with jumper selection for the eol.
It tells you on the info sheet that comes with the pir, use 10k and 22k for the R8plus.
Regards
correct. you got it :) just make sure you get the resistor the right way round, as the panel will look for the tamp value as default...if this is not the case it will display a tamp fault on zone xx...
Thanks again. I think I have been lucky that I haven't wired them in before as the premier pannel you just use the jumpers to set the value.
LED
i apologise , did not know this particular pir came with onboard resistor. just use the jumpers to set the value stated for tamp and alarm..and wire one pair of wires as per diagram. i was thinking you were going to have to hard wire the resistors in... banghead
