Dabsbhatti Posted June 16, 2008 Posted June 16, 2008 I've just setup a galaxy G2 44. I'm having problems unseting the system after a full set when I initiate the entry sequence. It doesn't accept any of the user codes during the normal entry time period. I enter the code and press enter and keypad just displays system set until the enty sequence times out and an alarm signals. When that happens I can use the code to disarm ok, system then indicates an intrusion on the final exit door. I done some testing and I can disarm and arm ok on a full set as long as I don't initiate the entry sequence. When I try with entry sequence i.e opening front door, entry timer starts ok, I enter my code and nothing ...just get a system set message. Is there something I've programmed wrong or faulty panel maybe?
Guest RJBsec Posted June 16, 2008 Posted June 16, 2008 Is there something I've programmed wrong or faulty panel maybe? Yes - DD243 requires that the keypad be disabled on entry and that's the panel default. You don't require that (no police response) so disable it in the programming menu that deals with DD243.
Dabsbhatti Posted June 16, 2008 Author Posted June 16, 2008 That did the trick, working a treat now. Thanks very much.
