Adding 2nd Keypad To Galaxy
I want to add a 2nd keypad to a galaxy, twin AB line Daisy chain config. According to the manual I have to terminate the new AB line with 680 Ohm and remove link LK1 on the panel. Can this be done in engineer mode or is it best to power down the panel completely before hand? Also, if I power down the panel can someone confirm I won't lose the user setting and codes and zone configs I've setup already. Thanks.
Guest RJBsec
Power down from day mode before making the change, you will not lose the programming but you will have to reset the date & time.
personally i thought the procedure was
1) put panel into eng. ode
2) add keypad
3) go to the 'restart' command in paremeters , and follow instructions - i think it goes back to day mode so ensure you have customer code
4) system will ask you to confirm new keypad/rio etc
exit engineering if still in.
the only wat the galacy will lose data is if is faulty or if the memeory link not enabled
Again the above is my understanding re original galaxy - i am not 100% sure if same applies to newer versions
Paul
THE BLACK KNIGHT
Way I have always done it:
Put panel into engineer mode
Cable and address new device
Connect A and B to data
Connect power
Exit engineer mode (you should get "1 MODS ADDED" message, press A or ENT to view the type and address of the module)
Check keypad is functional
Go back into engineer mode and check the keypad comms in the diagnostic menu is showing 100%
Trade Member
But if starring from the panel, you need to terminate the line, and remove the termination at the panel. I wouldnt advise cutting anything on a powered up panel.
You can only run 2 lines from a galaxy (per data line) as you need to terminate both ends with a 680 Ohm. Most of the time the panel is at the end of the line so needs its resistor. Alternativly cable it of the existing line and move the eol resistor.
Guest RJBsec
Connect power
2) add keypad
Paul
I would agree with the above on simply adding another keypad (or component on the data line) but personally I would not do that where I was splitting the data line as o/p intends doing - I would power down to avoid possible problems, mind you I don't trust panels any longer.
Will power down as suggested. Thanks for advise.
