Info On Wiring
hi all
i am new to the forum so hi to you all
i am looking for a wiring diagram to connect a pyronix vocaliser to an aritech cs350 control panel
i installed the alarm about seven years agop and it has worked fine since
i live in the country so would like it to text me if it goes off
thanks in advance
jm
Guest RJBsec
I didnt think the vocaliser could text?
Me neither, autodialler only IIRC.
...... from a yr. 2000 manual
The Vocaliser provides a means of relaying appropriate speech messages to a certain set of
telephone numbers on specific alarm activations. The Vocaliser will make repeated attempts to
connect until it is successful. A local alarm inside the premises may be generated if the Vocaliser
detects a cut telephone line.
This manual covers all the commands that the user is able to perform. It assumes that the
Vocaliser has already been installed and programmed correctly using the Installation instructions.
Common message Emergency, this is John Smith, 12 The High Street, Leeds.
Alarm message 1 An alarm activation has taken place.
Alarm message 2 A Personal Attack has been detected.
Alarm message 3 A fire has been detected
Alarm message 4 The power supply has been lost
Common message
got only two in place, no they do not text, unless they have being updated
