Guest Bolion Posted June 20, 2003 Posted June 20, 2003 Hello, i need to do a logical AND function output on a windsor 700 panel (default is OR). This cannot be modified via keypad but only with a soft called "WINDSOR 700 CONFIGURATION EDITOR" (maybe "guradstation local" can do it but i haven't it so i cannot try) If anyone have something about it...(or the configuration EEPROM adress map will also help) Any help would be great.
