Seve Posted June 19, 2008 Posted June 19, 2008 Gents, We have just had delivered a portacabin that has an A1 security alarm fitted. The cabin has been wired up and the alarm appears to function correctly. The installation i.e. un-switched fused spur is fitted so electrically looks ok, however, knowing absolutely nothing about alarms will this age of alarm meet current regulations? and if not are we still allowed to use it? Regards, Seve
Guest anguscanplay Posted June 19, 2008 Posted June 19, 2008 Gents,We have just had delivered a portacabin that has an A1 security alarm fitted. The cabin has been wired up and the alarm appears to function correctly. The installation i.e. un-switched fused spur is fitted so electrically looks ok, however, knowing absolutely nothing about alarms will this age of alarm meet current regulations? and if not are we still allowed to use it? Regards, Seve first check with your insurer but as its not been installed today I can`t see a reason to HAVE to upgrade ...........
luggsey Posted June 19, 2008 Posted June 19, 2008 Gents,We have just had delivered a portacabin that has an A1 security alarm fitted. The cabin has been wired up and the alarm appears to function correctly. The installation i.e. un-switched fused spur is fitted so electrically looks ok, however, knowing absolutely nothing about alarms will this age of alarm meet current regulations? and if not are we still allowed to use it? Regards, Seve I would get it serviced by a local company to ensure correct operation. ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
Guest RJBsec Posted June 19, 2008 Posted June 19, 2008 Gents,We have just had delivered a portacabin that has an A1 security alarm fitted. The cabin has been wired up and the alarm appears to function correctly. The installation i.e. un-switched fused spur is fitted so electrically looks ok, however, knowing absolutely nothing about alarms will this age of alarm meet current regulations? and if not are we still allowed to use it? Regards, Seve It is unlikely to meet current regulations. You can certainly use it, however if you require a police response or as angus says if there are insurance requirements, then you will need to upgrade via the services of a professional installer.
