djandysp Posted June 21, 2008 Posted June 21, 2008 I ordered RS232 loom with 9 pin serial connector, and its this cable i wanted to make up as the one ordered has still not arrived. You cant make it up unless youve got the connector to go into the msx card as well dont think castle have made the wiring map available but i can ask the question on monday
Graham750 Posted June 21, 2008 Author Posted June 21, 2008 You cant make it up unless youve got the connector to go into the msx card as well dont think castle have made the wiring map available but i can ask the question on monday I have access to all the connectors I need, so to make the cable is simple. I checked their website they dont make the pinouts available. Have a word on Monday if not Ill let you know what the pinouts are when I get them. I am sure it would be handy for you engineers on here and will save you
Barsnake Posted June 21, 2008 Posted June 21, 2008 I thought i'd make some up then found out they were only about
Barsnake Posted June 21, 2008 Posted June 21, 2008 White Castle Version Black One The Blue Peter Special (Yes It Does Work) And Before You Take The Mick The White Label Was When It Was A 9-9Way Lead For Something Else
Graham750 Posted June 23, 2008 Author Posted June 23, 2008 White Castle VersionBlack One The Blue Peter Special (Yes It Does Work) And Before You Take The Mick The White Label Was When It Was A 9-9Way Lead For Something Else Barsnake, Thanks for this I made up the cable on the info you provided and all is working a treat, thinking about how to convert rs232 to ethernet for lan access. Thanks for your help.
james.wilson Posted June 23, 2008 Posted June 23, 2008 Castle also do an ethernet card, perhaps you could have a word with your installer. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Graham750 Posted June 23, 2008 Author Posted June 23, 2008 Castle also do an ethernet card, perhaps you could have a word with your installer. ??? Not sure if the IP One lets you gain LAN access to Insite or just reporting to ARC
Barsnake Posted June 23, 2008 Posted June 23, 2008 Barsnake, Thanks for this I made up the cable on the info you provided and all is working a treat, thinking about how to convert rs232 to ethernet for lan access. Thanks for your help. My pleasure young man
james.wilson Posted June 23, 2008 Posted June 23, 2008 ??? Not sure if the IP One lets you gain LAN access to Insite or just reporting to ARC I see, just assumed. Dont actually use them anymore securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
