Gardtec 300
Looking for clues, if any one can help!
I need to disable the alarm as I am having a new kitchen fitted and they will need to turn the power off..only problem is that turning the power off means the alarm goes off... and my neighbours aren't going to be happy! Same problem happens when we have a power cut.. is there a quick way to disable the sounder??
Regards
Alicat502004
Link to comment
https://www.thesecurityinstaller.co.uk/community/topic/23772-gardtec-300/
Share on other sites
Agreed, for obvious reasons we cant discuss how to disable anything security related, regardless of reason. You need to call your service company anyway as an alarm shouldnt activate when the power is removed.
Guest anguscanplay
if you just turn the power off the alarm should stop after 20 minutes - no different to if it activated when you were out of the house and the neighbours don`t have any grounds to complain
your bigger problem is the systems likely to crash when the powers reapplied
Guest anguscanplay
might not though, depends on its age and if it has a timer
thanks for that LOL
Disabling advice is not given out on the forum - a local engineer could help you.
i thought this reply covered it fairly comprehensively and within the forums well know rules in the public area :unsure:
so why was there a need to say anything else?
regs
alan
