ajmooseman Posted June 23, 2008 Posted June 23, 2008 Afternoon All Sorry for not posting in the introduce yourself forum, but I just need one things from you guys I currently have Menvier TS900 Alarm system installed in my house, I just had an extension and pre wired for new key panel and PIR's NOW the bloody PCB has gone, well I say gone, it has a battery fault, Menvier say replace PCB, however TS900 was discontinued years ago, Can Anybody supply me with one?? Really don't want to buy all brand new kit just becasue of this. Many thanks Moose
lawandorder Posted June 23, 2008 Posted June 23, 2008 Afternoon AllSorry for not posting in the introduce yourself forum, but I just need one things from you guys I currently have Menvier TS900 Alarm system installed in my house, I just had an extension and pre wired for new key panel and PIR's NOW the bloody PCB has gone, well I say gone, it has a battery fault, Menvier say replace PCB, however TS900 was discontinued years ago, Can Anybody supply me with one?? Really don't want to buy all brand new kit just becasue of this. Many thanks Moose Are you sure this is a panel fault? Iused to fit a lot of TS900 and TS2500 in the late 90s and I have come across a problem similar to the one you describe on several occasions. As I recall the TS900 has a fairly sophisticated charging/monitoring circuit which refuses to charge a flat battery. If the battery has gone into deep discharge it will look like it is short circuited and the panel will refuse to charge it. It might be worth trying a fresh battery which you know is charged. I'm not trying to teach you to suck eggs and I apologise if you have already explored this possibility but it might save you some money if it is only a discharged battery. The TS900 was a pretty good panel in my opinion and apart from lightning strikes I never had a faulty one. They do occasionally pop up on a well know auction site if you do need to buy one.
ajmooseman Posted June 24, 2008 Author Posted June 24, 2008 Are you sure this is a panel fault? Iused to fit a lot of TS900 and TS2500 in the late 90s and I have come across a problem similar to the one you describe on several occasions.As I recall the TS900 has a fairly sophisticated charging/monitoring circuit which refuses to charge a flat battery. If the battery has gone into deep discharge it will look like it is short circuited and the panel will refuse to charge it. It might be worth trying a fresh battery which you know is charged. I'm not trying to teach you to suck eggs and I apologise if you have already explored this possibility but it might save you some money if it is only a discharged battery. The TS900 was a pretty good panel in my opinion and apart from lightning strikes I never had a faulty one. They do occasionally pop up on a well know auction site if you do need to buy one. Many thanks for the reply I'll try tonight, certainly worth a shout. Will let you know.
ajmooseman Posted June 26, 2008 Author Posted June 26, 2008 Little update But a fully charge new battery on Tuesday night, warning led on PCB went straight off, however battery fault on all LCD panels still remains. Dont think the board is producing enogh ummf to charge battery but not had chance to get a meter on it yet, going to try tonight. I think if i not the mains off and drain the battery, then the battery will not recharge, the meter will tell tonght. systems tests via panel states 13.6v output to battery but I'n conviced. So still on the look out for a new or PCB
