redwards Posted June 25, 2008 Posted June 25, 2008 Anyone out there with good memory on the Vista 4110 panels??? Probably time to replace the system but it seems to be a simple problem.. I have an error message on the keypads - OC and no AC. also no power light. this error does not appear in the only booklet i have available we have has mains power in and 14volts across the outputs from the board.. any ideas gratefully received.. regards
The Max Posted June 25, 2008 Posted June 25, 2008 Anyone out there with good memory on the Vista 4110 panels???Probably time to replace the system but it seems to be a simple problem.. I have an error message on the keypads - OC and no AC. also no power light. this error does not appear in the only booklet i have available we have has mains power in and 14volts across the outputs from the board.. any ideas gratefully received.. regards oc generally means no data getting to the keypad. However make sure the heypad is addressed as 31. To do this down power keypad and power up with the 1 & 3 keys held in together and the keypad address appears on the top LHS, if it is not addressed as 31 then type in 31 and then * to save. Hope this helps
redwards Posted June 25, 2008 Author Posted June 25, 2008 oc generally means no data getting to the keypad. However make sure the heypad is addressed as 31. To do this down power keypad and power up with the 1 & 3 keys held in together and the keypad address appears on the top LHS, if it is not addressed as 31 then type in 31 and then * to save.Hope this helps can't get any response from the keypads. they are dead to the touch although the error message is on screen
The Max Posted June 25, 2008 Posted June 25, 2008 can't get any response from the keypads. they are dead to the touch although the error message is on screen Have you tried wiring the keypad at the control panel just on a flying lead?
redwards Posted June 25, 2008 Author Posted June 25, 2008 Have you tried wiring the keypad at the control panel just on a flying lead? OK - looks like it was something with the battery circuit (battery is OK). linked out the circuit and re-booted on mains only and now its working. Wierd !!!! thanks for your help regards
redwards Posted June 26, 2008 Author Posted June 26, 2008 What you planning to do next redwards?C. got the keypad operational and after about 3 attempts to clear an 09 alarm it settled down and is now running (without battery) then i went to the pub !!!! regards
Chorlton Posted June 26, 2008 Posted June 26, 2008 got the keypad operational and after about 3 attempts to clear an 09 alarm it settled down and is now running (without battery) then i went to the pub !!!!regards eh OK. What i mean is to rectify the "no battery" situation.
redwards Posted June 26, 2008 Author Posted June 26, 2008 eh OK.What i mean is to rectify the "no battery" situation. not sure what to do with it, have reconnected the battery today and the system is now working OK. not sure what happened with it, obvioulsy very limited diagnostics available. maybe i will look to upgrade the panel..
Chorlton Posted June 26, 2008 Posted June 26, 2008 Cool. I was worried you were going to leave it without battery backup because that opens the door (normally at 3am) on another world of problems! C.
