Veritas 8.
alanb2
Hi,
I hope someone can help me on the following two points.
Firstly. On the Veritas 8 I believe that the correct procedure for changing the factory set engineer code is as follows. Enter existing code (XXXX), Press prog, press 60, enter new 4 digit code, press prog, press reset.
Could someone confirm this please.
Secondly. How do you change the factory set user code (XXXX) ?
Many thanks in anticipation.
Regards,
Alan.
