shep78 Posted July 1, 2008 Posted July 1, 2008 Hi all, I'm not sure whether anyone can help? My TS700 system is displaying 'L6' on the LCD display after the power was off whilst my electrical sockets were updated and replaced. The code doesn't appear to be listed in the manual and I've tried everything the manual suggests, although cannot seem to get it to alarm to set/not display 'L6'. When entering the alarm number/code it goes into all the menus and evrything works ok, but the system wont set and reverts back to the 'L6' on the LCD panel once out of the menu. What does 'L6' mean, is it knackered? Kind regards. Paul
breff Posted July 1, 2008 Posted July 1, 2008 Low Battery,(lb), it may recharge but depending on age and how long the power was off it may be best to fit a new one. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
justin Posted July 1, 2008 Posted July 1, 2008 It will be 'Lb' Low battery. If the panel will not reset after a couple of hours. Replace the battery.
Alarm Protection Posted July 2, 2008 Posted July 2, 2008 Replace the battery then see what happens! !
shep78 Posted July 3, 2008 Author Posted July 3, 2008 Thanks for the responses guys. That is obviously why you guys do what you do and I work in an office... Thanks again.
Chorlton Posted July 3, 2008 Posted July 3, 2008 Thanks for the responses guys. That is obviously why you guys do what you do and I work in an office... Thanks again. Thanks for the thanks shep78! Maplin (or similar) for a battery & switch of the power to the alarm and be careful what you touch whilst changing it. Let us know how it goes! C.
