Accenta 6 PIN code
Guest markj
Guest markj
I have recently moved into a house installed with Accenta 6 keypads. We do not know what the PIN code and can't get the info from the previous occupant, so we cannot use the alarm system.
Is there any way around this?
Guest dale
Give an alarm company a call and they will service your systems and default and reprogramme the system to your requirements.
Dale
Hi ,
Try the default code 0,1,2,3.
If this doesnt work , the panel will need defaulting and reprogramming.You could arrange a service and get it defaulted at the same time , (or get hold of the installer guide and do it yourself).
B)
