mummyneh Posted July 6, 2008 Posted July 6, 2008 Hi, I am having trouble connecting the wiring to the bell box for a scantronic 9651 with a 9940 with an Odyssey 1E bellbox. I was supposed to have someone come in and install it but he decided not to. My partner is very good with wiring and electrics. He has wired up the sensors and the control panel, but seems a bit confused with the bellbox. Any help would be appreciated. Thanks A wiring configuration would be much appreciated please A wiring configuration would be much appreciated please
james.wilson Posted July 6, 2008 Posted July 6, 2008 The Manuals will detail how to do this. Have a good read through them. James securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
mummyneh Posted July 6, 2008 Author Posted July 6, 2008 I am sorry if I seem really dim here but we have had a look at the manual and still cant work it out
james.wilson Posted July 6, 2008 Posted July 6, 2008 You are likly to damage something then, id have a word with another installer. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
shieldssecurity Posted July 6, 2008 Posted July 6, 2008 Hi,I am having trouble connecting the wiring to the bell box for a scantronic 9651 with a 9940 with an Odyssey 1E bellbox. I was supposed to have someone come in and install it but he decided not to. My partner is very good with wiring and electrics. He has wired up the sensors and the control panel, but seems a bit confused with the bellbox. Any help would be appreciated. Thanks A wiring configuration would be much appreciated please A wiring configuration would be much appreciated please if you can tell me the connections on the odyssey i will be able to tell you where to connect them on the panel "25 years of experience has taught us to care about the smaller jobs and given us the expertise to succeed in the larger ones"
mummyneh Posted July 7, 2008 Author Posted July 7, 2008 if you can tell me the connections on the odyssey i will be able to tell you where to connect them on the panel Bell connection -ve N/C --------- Battery +ve -ve ---------- Sounder output +ve MSW2 --------- Micro Switch MSW1 S (Strb -ve) D (0V) C (TAMP) B (BELL -ve) A 12V (+ve) this is how he has done the wiring on the control panel 9940 red- 12v black - 0v green - Pyronix sensors earth - blue(used on pyronix sensor) yellow and white - tamper if you can tell me the connections on the odyssey i will be able to tell you where to connect them on the panel Bell connection -ve ) N/C ) --------- Battery +ve ) -ve ) ---------- Sounder output +ve ) MSW2 ) --------- Micro Switch MSW1 ) S (Strb -ve) D (0V) C (TAMP) B (BELL -ve) A 12V (+ve) this is how he has done the wiring on the control panel 9940 red- 12v black - 0v green - Pyronix sensors earth - blue(used on pyronix sensor) yellow and white - tamper
arfur mo Posted July 7, 2008 Posted July 7, 2008 you have posted references to the detectors, but say they have been wired successfully. the confusion you seem to show means the 1st advice given by James was the really best option for you to follow, or you might damage something. failing that, refer to whoever supplied it to you for further one - on - one guidance. regs alan If you think education is difficult, try being stupid!!!!
hpotter Posted July 7, 2008 Posted July 7, 2008 Hi,I am having trouble connecting the wiring to the bell box for a scantronic 9651 with a 9940 with an Odyssey 1E bellbox. I was supposed to have someone come in and install it but he decided not to. My partner is very good with wiring and electrics. He has wired up the sensors and the control panel, but seems a bit confused with the bellbox. Any help would be appreciated. Thanks A wiring configuration would be much appreciated please A wiring configuration would be much appreciated please Choose your own colours: A (bellbox) = 12v = 12v aux (9651) D (bellbox) = 0v = 0v (9651) B (bellbox) = bell trig = op1 (9651) S (bellbox) = Stobe = op2 (9651) C (bellbox) = tamper = TR (9651) Also move the red lead from the nicad battery in bellox from NC to +ve mind the strobe, gives out 4000v You could call a local engineer, might not be as expensive as you think.
