Premier 48 Pannel / Electronic Door Latch?
Hi,
I am looking to fit a door latch release, I was wondering if there is anything available that would allow me to control this from a Premier 48 pannel. I didn't want to have to fit another keypad as a seperate system - also because of power failure etc if I didnt need to as there is an alarm keypad right next to the door in question.
Ideally if I could tap in a pin and have the latch trigger that would be great.
Regards
John
yes can be done. A engineer code will be needed to do the programing. only a door strike will be needed. plus maybe a psu to power the strike
Mark Terry
A.M.I. Security
Covering the Thames Valley
Tel. 01189 775173 24hours
mark.terry@amisecurity.co.uk
Thanks for the info, I'll see what I can find. Better dig out the manual again..
