Alarm Randomly Sets Of Problem
:hmm:
I'd be inclined to disconnect everything, save the keypad, and loop out everything (rather than dis in programming).
See what happens.
If all ok, put external sounder on, see what happens then.
and so on.
If all was working before, I assume you have moved bits (panel?) about so would opt for proving panel ok 1st.
Have you re-routed cables?
Yes the alarm worked perfect before.
Yes i have rerouted the alarm system
Zone 2 - 8 Are Not Used
Zone 1 Door Magnet
Since i played around with the tamper it aint gone off....
Zone 1 Door Magnet
What tamper did you play with?
Guest anguscanplay
holded it pressed reset on the alarm and let it go :) alarm goes off
could have been all it needed - hope it`s worked
