Broadband And Redcare
Assuming this is the best place to post this...
What is the official situation with having redcare classic and broadband on the same line? By broadband, I mean ADSL rather than cable...
Are they happy partners or not - I never seem to get a definitive answer..
thanks,
Andy
Manufacturer
thanks,
Andy
Can you have RedCARE on a broadband line?
Yes, as long as the broadband is supplied via an analog line.
But remeber no Fax/Credit Card Machines or SKY
Can you have a DC on a broadband line?
Yes, if a Filter is fitted, the DC has to be treated like a telephone
Providing its a 3GSTU it is ADSL compatible, older STU's are not.
http://www.redcare.bt.com/partner/product_mcd.htm
The redcare modem compatibility device (mcd)
allows end-users to connect redcare alarm
monitoring to data applications such as PCs,
EPOS, PDQ machines, credit card machines,
Digital set top boxes or fax machines
Guest anguscanplay
same here Gus, Just a quote to show they are compatable
