Guest RANDAL Posted May 30, 2004 Posted May 30, 2004 FOLLOWING ENGINEER MENU SET UP DOOR CHIME TO MAGNETIC DOOR CONTACTS (REED SWITCH SURFACE) PROBLEM IS, OPEN DOOR DOSENT WORK NO CHIME, OPEN DOOR AGAIN DOES WORK VERY INTERMITENT WORKS WELL WHEN ALARM IS SET BREAKS CONTACT SETS ALARM OFF ANY IDEAS WITH REED SWITCHES THANKS RANDAL B)
FASTCAR Posted May 30, 2004 Posted May 30, 2004 Use the walk test to ensure the contact is working correctly.Some panels need the chimes back turning on after coming out of engineer program.
Deltaseven Posted May 30, 2004 Posted May 30, 2004 Do I need sleep or coffee? I really did not understand that post! Something to do with chime on a door contact I think? I am not trying to be rude, but a clearer request will get more answers... Apologies if it is just me being slow... D7
Mister_Dave Posted June 1, 2004 Posted June 1, 2004 Are You sure the door contact is not set to double knock. Dave Oxendale York based security systems engineer.
