dazzler Posted July 16, 2008 Posted July 16, 2008 Hello Everyone Was wandering whether anybody uses or knows of a reliable small domestic panel with a programmable High-Low ouput i.e Alternating 12v 0v 12v 0v 12v etc. I am trying to integrate an alarm system with an external appliance, so that the external appliance is activated upon an alarm condition. The external appliance needs to be triggered by 0v applied, every 1-5 seconds continuosly during an alarm. If nobody knows of one, was thinking(not too hard obviously) about programming a normal panel output as alarm, and using a Delay Release Module from TK consultants. When it is in Non-Latched(timed) mode, the relay time will be set between 1-5 seconds. After the timer counting down and relay settling back to its normal state, obviously a 0v trigger is still present from the alarm(providing the user has'nt switched it off) therefore switching the outputs for another 1-5 seconds........and so on until the system is unset/reset. Has anybody used a delay release mod from TKC for a similar situation to this or even better know of a capable panel? Hope some clever cloggs can shed some light on it! Thanks :
james.wilson Posted July 16, 2008 Posted July 16, 2008 If its a custom, and you dont want to build something dedicated, how about an old indicator module. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
sasa Posted July 17, 2008 Posted July 17, 2008 If I was you, I would make a small electronic device using just one IC (555), one transistor and a few capacitors and resistors. I will send you a schematic if you are interested in this solution.
arfur mo Posted July 17, 2008 Posted July 17, 2008 If I was you, I would make a small electronic device using just one IC (555), one transistor and a few capacitors and resistors.I will send you a schematic if you are interested in this solution. the ciruits called an 'astable multivibrator' i dont think the tk modules will pulse unless you feed the input via its own springs so the board operates removes the signal, times out reapplies the signal and so on. many panels have a programable output but only deliver about 50 ma, as you want it to go with the alarm then use the bell or strobe output, then just about any panel will do. might be better to post what you want to achieve, the wealth of knowledge in here will man someone has either done it or tried it and failed, this is the easy way to find out the pro's and con's or get perhaps a more elegant solution. regs alan If you think education is difficult, try being stupid!!!!
hpotter Posted July 17, 2008 Posted July 17, 2008 Hello EveryoneWas wandering whether anybody uses or knows of a reliable small domestic panel with a programmable High-Low ouput i.e Alternating 12v 0v 12v 0v 12v etc. I am trying to integrate an alarm system with an external appliance, so that the external appliance is activated upon an alarm condition. The external appliance needs to be triggered by 0v applied, every 1-5 seconds continuosly during an alarm. If nobody knows of one, was thinking(not too hard obviously) about programming a normal panel output as alarm, and using a Delay Release Module from TK consultants. When it is in Non-Latched(timed) mode, the relay time will be set between 1-5 seconds. After the timer counting down and relay settling back to its normal state, obviously a 0v trigger is still present from the alarm(providing the user has'nt switched it off) therefore switching the outputs for another 1-5 seconds........and so on until the system is unset/reset. Has anybody used a delay release mod from TKC for a similar situation to this or even better know of a capable panel? Hope some clever cloggs can shed some light on it! Thanks : Not sure what you trying to achieve but you could look at e.g. scanny 9651. change op3 (Command 83) to bell, then command 184 to make panel pulse o/p. Used to give fire a different sound to intruder. you would have to make a zone a fire zone so if you want it to work on intruder use relay contacts to scct fire zone and put relay coil (c/w back emf diode) across op1 n +ve
SUBS Posted July 17, 2008 Posted July 17, 2008 You could build up a multivibrator, RS sell a PCB for 555 timers, and the RS 555 data sheet has loads of circuits, you could do it all for about 30 bob ! you can download the data sheet free, If you have no RS account, , maplins probaly do something similar. then trigger it from the bell or strobe output. Curious to know what it is your trying to achieve though !
Guest anguscanplay Posted July 17, 2008 Posted July 17, 2008 Curious to know what it is your trying to achieve though ! I`m thinking electrified door handles
SUBS Posted July 17, 2008 Posted July 17, 2008 I`m thinking electrified door handles Spose its one way to protect your customers ohm. Shockin innit, absolutely revolting idea........ Sorry !
technicalwizard Posted July 17, 2008 Posted July 17, 2008 Mmmmh, could use a Texecom 48 has programmable outputs does anything you want timers and sechudles etc. www.texe.com
