Scantronic 9752 Lost Password Nv Ram Reset ?
Hello All,
I have a Scantronic 9752 panel which I have wired with a number of PIR's and two keypads
I am powering it up as per instructions (installed two 9751's) before and I have kickstarted it
However when I go to the panel and enter 'default user code' or 'default engineer code' I get 'Invalid Code' I have also tried 'default user code' and 'default engineer code'
I have tried removing the power and then shorting the NVRam reset pins and repeating
The fault does not go away.
How long do you need to short the NV-RAM clear pins and does the panel have to have power supplied to it or not ?
Thanks in advance
james
Hello All,
However when I go to the panel and enter '1234' or '7890' I get 'Invalid Code' I have also tried '123456' and '567890'
Thanks in advance
james
