james.wilson Posted July 25, 2008 Posted July 25, 2008 you will lneed to enable the walk test led to see the senosrs activating. Also you only need antimask on a Grade 3 job, as your doing it yourself grade 3 cannot i assume be a requirement securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
vrstu Posted July 25, 2008 Author Posted July 25, 2008 So am I better to remove the antimask packing then? I've managed to change the default engineer code but I can't see how ot disable the default user one. Any ideas?
james.wilson Posted July 25, 2008 Posted July 25, 2008 the creep is usually masked off (different to anti masking) but if you have small rooms then you can remove it. you cant disable the user code, an engineer can only unset if armed with the engineer code so cannt be used for normal setting etc. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
vrstu Posted July 25, 2008 Author Posted July 25, 2008 So if the default user code is released into the public domain, which to be honest it is, then anyone could disarm the system with that 4 digit code?
Guest anguscanplay Posted July 25, 2008 Posted July 25, 2008 So if the default user code is released into the public domain, which to be honest it is, then anyone could disarm the system with that 4 digit code? though everyone changes there code so in reality it wont happen ( tongue firmly in cheek) give me a half hour I could probably guess yours!!
james.wilson Posted July 25, 2008 Posted July 25, 2008 you need to change it of course, you just cant disable the manager code, it needs at least one code in it. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
vrstu Posted July 26, 2008 Author Posted July 26, 2008 That's where I'm stuck then. I have added three users and set codes and KeyProx for those but the default entry code still works and I can't see which user I would need to change to get rid of that.
camerabloke Posted July 26, 2008 Posted July 26, 2008 user 299 is manager Eucam Security Systems 0845 4630 746 www.eucam.co.uk
vrstu Posted July 26, 2008 Author Posted July 26, 2008 user 299 is manager Thanks, so if I edit 299 then that will modifiy the preset default access code?
camerabloke Posted July 26, 2008 Posted July 26, 2008 correctamundo my friend Eucam Security Systems 0845 4630 746 www.eucam.co.uk
