Galaxy 2-20 Install Questions
vrstu
Right gents I seem to have caused myself a little problem here -
As above I changed the passcode for user 23 which I believe is the engineer login (user 23 is only visible after entering the engineer passcode). I've tried to get into the engineer menu today, firstly enter a normal user code then allow access and then back out to the main screen and enter the new engineer code but when I try to access the engineer sub menu it tells me I have isufficient rights to access it.
User 23 is shown as a master user - is this correct.
Thanks guys.
I'm pretty sure that by changing the user 23 password I have changed it to Manager access instead of installer. Anyway I can get this back?
IF i recall form memory user 24 is installer, user 23 is master/manager
But you need to enable installer access from the manager menu else you will get an insufficient rights message.
This is a requirement of EN50131 as you need to give permission to access the installer menu.
James
If I log in as a user I can only see up to user 22, however if I log in using the pass code that I set for user 23 I can then see user 23. I can't see any more users than that and the user that I modified the pass code for to stop the default pass code was 23 and now the default pass code doesn't work.
I know what my engineer code is and even when I enable engineer access in Modify (Change 0 to 1 to enable L3 access) I still don't have the access rights of an engineer. THe only thing I can assume is the I have somehow modified the access rights of the engineer access.
Right - I'm soreted with the access problem now, managed to do a default and get the codes reset.
Hopefully one last question -
I don't subscribe to a monitoring service but I do want to use the SMS feature (Option 44 and Option 56/1/17)
If I put the Galaxy SMS centre number into my panel 56/1/17/2 and trigger the alarm I get a Line fault followed by SMS fault. As soon as I remove the number obviously no faults.
Can somene please please point me in the right direction with this, I get the feeling I am missing something quite basic here.
Thanks.
