Pre 2nd Fix Tests
Fire loop check.......
I try and start at the panel end and check the loop as I fit devices.
What pre- second fix tests should be done on a fire loop? If any cheers
Start by linking all the devices through and doing a continuity test. (don`t megga with any devices on LOL)
Panel should soak test I usually have that on the wall powered up with no loops connected .
Then start adding the loops one at a time.
When your happy that the loops are clear add devices
Peter Robinson
Freelance
M:07889038650
So connect all the cores through back to the panel, when it sees no fault start 2nd fixing? Is it essential to record contiunuity/ resistance readinds on the loop?
:rolleyes:
Guest G.J.M
insulation tests
earth loop impedance tests
voltage drop
loop resistance test to see if correct amount of cable has been used.
continuity
autolearn
etc etc
test all looop isolators
test internal loop isolators
open circuit loop in and full load test
open circuit loop out and full load test
test all loop devices.
slightly more than "if any"
:rolleyes:
If you want to comply with BS5839 it is essential to record the following readings for all loops:
1. Insulation resistance L-N, L-E, N-E
2. Loop Continuity - L-L, N-N, E-E
However this is easier said than done when you attend site to commission and the electrical contractor has already fitted all the devices!!
cheers.
Guest G.J.M
it's up to the installing electrical contractor to do all the insulation tests and record them...in theory
