Gardtec Novatel Sounder
jackbuchan
Could someone advise on how to program this on a gardtec 595 panel as i have everything else installed not sure what to set this bell as on the sounders in engineer mode !
also can you tell me were the connections should go in relation to the panel and bell
is it possible to connect up the bell without it going off when you connect the battery terminal??
kind regards,
jack buchan
Kind Regards,
Jack Buchan
JDB Solutions
Web: www.jdbsolutions.co.uk
E-Mail: jack@jdbsolutions.co.uk
Most external sounders will go 'off' once you connect the battery-leave it connected and it should shut up after a few seconds.
Rich.
I would just wire them as standard, as per the instructions supplied with the sounder. I would'nt consider using the NovActive feature unless I was fitting more than one bell box.
Connect the battery up and the sounder will silence after 3 or 4 seconds. You can then wire it up and put the lid on without it sounding again, unless you trigger it from the panel or take the lid off.
Trade Member
