Speaker Output On Galaxy
mick m
im having trouble making a speaker work on a galaxy 500 panel. when i put the wires in the horn connections nothing happens, or when i put them in an output same again (programmed as horn).
edit: since posting i was testing by using the option 32 test outputs (17 horn and 18 e/e horn) = nothing. but when setting (code + A) voila! it works (from the horn output on the main pcb), so i know the speaker is ok.
but i want to wire the speaker off a rio, and use it as for chime. the manual says use a 3.3K pull-up resistor, still no luck. any ideas please?
you cant run a normal speaker from an output. A spk requires AC (the horn output) a rio and all the other outputs provide a pulsed dc output. YOu will need a buzzer or a driver for that speaker. They are called hi lo sounders, we used to use a CK model but now use a ventcroft one that emits a constant tone on its low input that mimics the main speaker noise
  • 3 weeks later...
  • 3 months later...
Output 99 is used for the speaker on a galaxy 500 make sure you have that output programmed right including the group option.
jobs@mintsecurity.co.ukĀ  01246 888444
You mean the ventcroft one that the micro switch falls out as its not fixed in at all, just sort of slots in a hole.
We have been using them for a while due to the very low current in alarm, but now back onto the CK ones.
