Help...help...signal Control Module
I have Kidde Thorn Fire Alarm and I will to maintenance this FACP but I don't know how to install the FA wire to Signal Control Module. I attach a image of device.
Thanks
Guest G.J.M
do you mean connect to a digital communicator/redcare?
good luck on the maintenance. I would frightened to breathe on it in case it pops.
Thanks
No....I need the installer manual. The bottom connection is for detector wire but for the top connection I don't know yet. I means functions each connection at this device.
regards
