Difference Between Grade2/grade 3 Door Contacts
Guest anguscanplay
But i thought we were discussing G3?
But re tampering of BT joint, where would you stop?
As a tool is required to disconnect the block it isnt tampered, if the line was disconneted at the block, to dp, the pole etc the panel will report a line fault. Same with IP as long as a tool is required then its ok, what you cant do is use a std cat 5 socket and patch lead as no tool is req to disconnect. There is a whole guide on signalling connection location etc coming from the BSIA. Ie no comms in entry routes etc
But again this is all only G3, G2 as a low to medium risk can just be plugged in which is why IMO G2 will over the next few years be accepted less and less.
but more likely someone is going to have a look inside a BT block than a door contact - thats what brought it to mind here (sorry)
agreed, but looking in the block or the dp or the road cabinet etc is fine. If its disconnected a line fail would be detected. While i used to think personally that blocks should be secure etc then you think about the rest of the bt network and tampering the one adj panel is pointless unless your gonna do the lot ie all the way back to exhange. Thats why redcare and its varients/competing versions, is so popular
they are old Grade 3 ones then, from before the reg change, cqr by any chance?
So there is an old and new Grade 3 !!! :angry2: Yes they are cqr type, are they still acceptable? The rules seem to be changing all the time. Where can i find the rules/document for grade 2/3 systems, i cant seem to find much on the net. The national company i work for have provide this info to all engineers but there seems to be alot more to this.
Grade 2
user must allow Engineer access
4 digit codes are allowed
12hr battery back up
max entry time 45 secs
set indicators max 180 seconds
system to be set by, contact set, p.t.s, external reader,chubb lock or ARC
Linefault/network fail should indicate on keypad
code/fob to display faults
Grade 3
5 digit codes must be used
panel to perform load test on all batteries
motion sensors to report ant-mask
back tampers to be used on motion sensors
its a start that but yes there is a lot more to it than that. The only way to be sure is you will need copies of the current std's
There are many parts to 50131 and you will need them all but you could start with part 1.
The reason for the old and new G3 is there was a dual running period using the old ones, that ran out a while ago.
Guest anguscanplay
Grade 2
user must allow Engineer access can be a on permenant allow
tamper required on all detection devices
12hr battery back up only if mains fail signalled
system to be set by, contact set, p.t.s, external reader,chubb lock or ARC or timed
Grade 3
user must allow Engineer access as above
5 digit codes must be used 5 digit?
12hr battery back up as above
set indicators max 180 seconds except on an external device - no limit
panel to perform load test on all batteries should do this at grade 2
TBH no one ( and i mean no one) actually knows what the regs say, maybe that will change when they are finally issued
er.
Yes they do gus. And they are issued
They you go, two posts two different views :D
Timed set and permanent engineer access?
also on the subject of grade 3 contacts what a pain in the butt they are. getting the distance of the gap right, getting the magnet the right way up, making sure the tamper is closed, man :( old contacts 2mins, grade 3 15-20 mins
Guest anguscanplay
told you didnt I............ James only sees what James wants to see
yeah - you can have a G2X - that doesnt need to be user action setting
the regs allow for the user to autherise the engineer once for life
try the knight plastic ones - best out of the bunch IMO
Guest anguscanplay
what the hell is a G2X ?
Grade 2notification option"X" = non signalling
