Whats this ?
Hi All, I know it says Chubb Sentinel CA66 on the panel, But im sure ive seen this panel before without the Chubb Branding on it.
What is this panel, anyone know the manufacturer ?
Guest Adrian
:?: mmm seen that at some point as well!
Looks a little like a C&K Active 5 maybe an early metal version.
Don't really know any one else any ideas?
Adrian B)
Guest andy jinks
the early c&k panel used the rascal super pcb (you needed 10 a levels to program it with the engineer manual)looks like chub re-badged it .i cant believe that a panel that started off at best dodgy has been copyed so many times.it started off as a rascal + then super then c&k then chub.
the funny thing is it was no good to start with.
Thanks all, I had thought it may be the rascal super in disguise, but it does also look simillar to the Active 5 panel a few have mentioned.
Guest Adrian
:banghead: mmm still non the wiser!!!! B)
Adrian B)
