Alarm
7blackdog7
On my Rascal+ I have a pir that is flickering at an accelerated rate when it detects. I assume that it is becoming unreliable. Are they easy to change and are they type specific or will a similar pir be ok.
Thanks.
Thanks.
Assuming its in a house & not eg conservatory, any 12v PIR will work. Would recommend not buying the cheapest though.
Could be worth asking a local firm to quote for a service at the same time. Battery to check/change etc. Might not be as much as you think, plus also youve then got a contact number if something did go wrong in the future.
I have a service contract, a new battery this year cost
