jamest Posted August 7, 2008 Posted August 7, 2008 Hi hope someone can help. I'm trying to fit a visonic 4 way receiver to a scantronic expander, I am told I can use it to have 4 wirefree zones connected to the expander. The receiver has 1 terminal for each zone and the expander I'm wiring to has 2 terminals per zone, how can this be wired? I'm hoping I'm missing something obvious. James This is a pdf for the receiver http://www.visonic.com/VisonicHomePage.nsf...nstructions.pdf
james.wilson Posted August 7, 2008 Posted August 7, 2008 YOu need the relay board that comes with it, or you will need to connect relays to those voltage outputs, to give the clean switch you need. James securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
jamest Posted August 7, 2008 Author Posted August 7, 2008 Thanks a lot for both the speed and quality of reply, I do believe that will solve it. James
