Galaxy 2-12
secure2007
hi there i have got a galaxy 2-12 fitted in my house. got it installed privatly. the installer gave us the manager code once when the system required a manager reset. but last night we had a power cut and the alarm was not activated and wen i went to activate it once the lights come back on the display showed alert enter code. so i entered my user code and looked at the fault and it was ac cu 002 or something like that. i pressed enter and it asked for a manager reset. i have got the 6 digit code but i dont know how, when and where to enter it. i tried calling the installer last night but he is gone to turkey for 4 weeks. and i need the alarm to work for tonight. can anyone please help me.
that sounds like a eng code then you need to activate level 3 acess menu 48 if i remember correctly
Mark Terry
A.M.I. Security
Covering the Thames Valley
Tel. 01189 775173 24hours
mark.terry@amisecurity.co.uk
but i'm trying to getting into the eng menu with that code as thats the code he gave me before and some how done the manager reset
2 things
YOu shouldnt be using an engineer code as you could do a lot of damage with it, if you press the wrong things when in there.
And you dont need the engineer code for this.
You need a MANAGER code, thats why its saying MANAGER RESET REQUIRED, Not ENGINEER RESET REQUIRED.
Acknowledge your alarms with your manager code and thats it.
James
thanks for your help everyone. i pressed the user code and changed level 3 access to enabled then went ot of the user mode and pressed the code the installer gave and it said there was a fault had a look at it and pressed enter then exited it and it said cecking for tampers and then i ggot out off the eng mode by typing the code and pressing esc
not a bloke called Sel is it?
Eucam Security Systems
0845 4630 746
www.eucam.co.uk
