InspectorGadget Posted August 8, 2008 Posted August 8, 2008 Hi. I have setup 2 modes ( full and bedtime ). I was wondering if there was an option on the Texecom Premier 48 or a way that I could configure the panel so that if it is part set for bedtime and it does trigger for any reason only the internal alarms on the keypad/s sound. I dont see the point of the external sirens going if I am in the house unless the PA is used. Ideally I would only want the external sirens to operate on full set mode only. Thanks.
breff Posted August 8, 2008 Posted August 8, 2008 You could program a part bell delay of perhaps 2 minutes. Look in Area timers The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
InspectorGadget Posted September 2, 2008 Author Posted September 2, 2008 You could program a part bell delay of perhaps 2 minutes. Look in Area timers Hi, Thanks for that, Ill look into it.
