DaleR Posted August 8, 2008 Posted August 8, 2008 Where can I get a bit of this stuff from, I want exactly the same outdoor cable that comes from the external junction box into my property?. I need a bit for a project i've got in mind, all totally legal nothing to do with any of BT's kit. Many thanks.
kka Posted August 8, 2008 Posted August 8, 2008 Where can I get a bit of this stuff from, I want exactly the same outdoor cable that comes from the external junction box into my property?. I need a bit for a project i've got in mind, all totally legal nothing to do with any of BT's kit.Many thanks. enlighten us all...there may be a subtitute......idea.visit a local demolition site and ask if there is any lying around Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
DaleR Posted August 8, 2008 Author Posted August 8, 2008 I've got 2 properties next to each other, running a wire from one to another and am in the process of building a line simulator unit for test/diagnostic purposes. i.e. it will function as a phone system but with only 2 phones/modems etc. Just to add this isnt the overhead dropwire10 with strengthening strands im looking for, its the external stuff they use from the junction box on the wall into the house. internal cable isn't quite good enough for the task.
Baracus Posted August 8, 2008 Posted August 8, 2008 You know this cable should only be about 2mtrs from where it enters the building due to fire risk?
kka Posted August 8, 2008 Posted August 8, 2008 You know this cable should only be about 2mtrs from where it enters the building due to fire risk? interesting please explain ? Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
james.wilson Posted August 8, 2008 Posted August 8, 2008 I think BA means the BT cable that contains the petroleum jelly, that cant be used inside. Not sure if its the same cable the op is refering too securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
DaleR Posted August 8, 2008 Author Posted August 8, 2008 I think thats the stuff that's terminated in junction box outside? then connects to the stuff I need which then goes to the NTE5
Lectrician Posted August 9, 2008 Posted August 9, 2008 There are loads of comms suppliers out there, but many will not simply sell to an individual. There is a company called FS Cables which sells specialist cables by the meter. We have used them several times in the past for duct grade comms cables, both petroleum filled, and not. Maybe google them. Email : martin@askthetrades.co.uk
DaleR Posted August 10, 2008 Author Posted August 10, 2008 There are loads of comms suppliers out there, but many will not simply sell to an individual.There is a company called FS Cables which sells specialist cables by the meter. We have used them several times in the past for duct grade comms cables, both petroleum filled, and not. Maybe google them. Thanks for the replies, I think the stuff im looking for is CW1128 or 1308b, which is petrolium jelly filled, so the fits with what Baracus said about the 2m thing, i'ts going to terminate in the attic less than 2m in then down to CAT5e/6 cable.
daiashthomas Posted August 16, 2008 Posted August 16, 2008 TLC Electrical Supply the stuff real quality with the vaseline stuff in it Trade Member
