New Alarm Help Needed Please
Hi Mike,
It all depends on how many zones you think need, i would recommend the veritas range.
Very easy to fit, even if your sparky is not that good with intruder alarms the veritas panels come with instructions.
If you need any more help/info let us know.
Paul.
Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
if you are trade and can get a hold of one..risco cpx fits your needs
I will be having it installed by my electrician who will be there doing some work on an extension we are having so it doesn't have to be DIY but does need to be friendly to program up and use ongoing.
Hi Mike
TBH ask your electrician/installer what he has worked with before because our experience and advice on here won't really help him (the man on the ground) if he gets into bother.
Any programming problems he encounters will either cost you by the hour to solve or be passed back to you as you bought the kit.
Because of the above I struggle to see how we can really help other than to say what "we" think "you" should buy for "him" to fit which is really no help at all.
Ask him then come back to us IMO.
C.
Hi Mike
C.
Thanks Chorlton.... I did start with the route in the first place even though he is a very good and experienced electrician for over 30 years and has all his certificates ..he
As you say you have wired in place and in the future would like to add wireless then the CPX would be the best as their wireless range cannot be beaten.
8 wired zones then 8 wireless via a wireless expansion unit plus keyfobs onto that. The unit will also call your mobile via the vo comm built into the panel if the alarm activates.
