August 11, 200818 yr comment_206893 Hi, I have just purchased a new house which has a Gardtec 300 series alarm. When I turn the power off it sets off the alarm. Am I right in thinking that it probably needs a new battery? If so is it something that I (who has no idea what he is doing) can change myself without annoying the neighbours too much? Any help would great. Thanks, Dan P.S Sorry if this is posted in the wrong place, which it probably is! Edited August 11, 200818 yr by newhomeowner Link to comment https://www.thesecurityinstaller.co.uk/community/topic/24357-gardtec-300-series/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 11, 200818 yr comment_206894 Hi,I have just purchased a new house which has a Gardtec 300 series alarm. When I turn the power off it sets off the alarm. Am I right in thinking that it probably needs a new battery? If so is it something that I (who has no idea what he is doing) can change myself without annoying the neighbours too much? Any help would great. Thanks, Dan )quite possibly )based on your statement in brackets I'd say best not. C. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/24357-gardtec-300-series/#findComment-206894 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 11, 200818 yr Author comment_206896 Thanks C, Any idea what it may cost me to get a pro in to sort it? Dan Link to comment https://www.thesecurityinstaller.co.uk/community/topic/24357-gardtec-300-series/#findComment-206896 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 11, 200818 yr comment_206897 Thanks C,Any idea what it may cost me to get a pro in to sort it? Dan Link to comment https://www.thesecurityinstaller.co.uk/community/topic/24357-gardtec-300-series/#findComment-206897 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 11, 200818 yr Author comment_206901 Ok thanks, What a pain in the //.B.W.F.//. Why can't the battery just simply be changed as with any other appliance? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/24357-gardtec-300-series/#findComment-206901 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 11, 200818 yr comment_206902 they do trickle charge but, the battery will deteriorate over time or if deep discharged i recon on 3-5 years normal life span Mark Terry A.M.I. Security Covering the Thames Valley Tel. 01189 775173 24hours mark.terry@amisecurity.co.uk Link to comment https://www.thesecurityinstaller.co.uk/community/topic/24357-gardtec-300-series/#findComment-206902 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 11, 200818 yr comment_206903 Ok thanks,What a pain in the //.B.W.F.//. Why can't the battery just simply be changed as with any other appliance? Emm ,sorry? Just like anything in life it is simple - if you know how. I could give you a quick run through it but because you said "If so is it something that I (who has no idea what he is doing) can change myself without annoying the neighbours too much?" I advised no accordingly. Do you know where the control panel is? Do you know your user code to silence the alarm when it sounds? Are you OK around fuses/electricity? Do you know where you will get the new battery from? If you are OK with the above just say so. No need to get miffed/upset as that just means nobody will want to help you. C. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/24357-gardtec-300-series/#findComment-206903 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 11, 200818 yr Author comment_206905 Sorry didn't mean to upset you! Yes I know where the control panel is, assuming thats the thing I put the code in to activate/deactivate the alarm? Yes I know the user code, but not the engineers code if that is needed. Yes I am ok around fuses/electricity. No I don't know where to get the new battery from, if you could please tell me what sort of battery I need i'm sure I could find one. A quick run through would be much appreciated. Thanks, Dan Link to comment https://www.thesecurityinstaller.co.uk/community/topic/24357-gardtec-300-series/#findComment-206905 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 11, 200818 yr comment_206906 Sorry didn't mean to upset you! I'm not.Yes I know where the control panel is, assuming thats the thing I put the code in to activate/deactivate the alarm? as long as it's not just a keypad, yes Yes I know the user code, but not the engineers code if that is needed. user only Yes I am ok around fuses/electricity. OK No I don't know where to get the new battery from, if you could please tell me what sort of battery I need i'm sure I could find one. 12v one but the size (Ah) will be specific to your alarm A quick run through would be much appreciated. Thanks, Dan 1)Switch of electrical supply to the alarm (whole house if unsure) 2)Open panel (alarm will sound if it has not already due to your current fault) 3)enter your code 4)take note of battey size (Ah) 5)close panel 6)switch electricity back on 7)buy a new battery - http://www.securitywarehouse.co.uk/catalog...keyword=Enersys+ 8)repeat steps 1-3 9)remove old battery 10)install new battery 11) repeat steps 5-6 C. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/24357-gardtec-300-series/#findComment-206906 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 11, 200818 yr Author comment_206907 Thanks, Thats how I thought it would be done. I just didn't want to open the panel, set the alarm off and find that I had to enter a different code to the normal one to shut it up and hence not be able to. If I can shut it up by entering my normal user code, I will give it a go before forking out for a full service. Thanks again, Dan Link to comment https://www.thesecurityinstaller.co.uk/community/topic/24357-gardtec-300-series/#findComment-206907 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
