Citadel Xr2/xr2+ & Remote
Kelcat
Hi, We've bought a house that comes with the above alarm & a couple of Key fobs. The telephone call system seems rubbish (won't recognise mobile phone key tones) but other than that it seems to work OK - except:
When you switch the system on the outside bell box flashes to let you know - when you switch it off it does nothing. This often results in us being in the house for a few moments & alarm sounds. Can this be changed? Alternatly can the volume of the internal sounder be adjusted (you can switch the alarm off with the fob from inside - but you can't really hear the internal alarm from where it is sited).
Hope the above makes sense & thanks alot for any help / advice.
citadel is a senate electrical branded panel prob an ADE optema/Acenta the strob can be progg not to flash when setting and i think their is a volume control in the panel ?? best get local Eng to service and adj at same time . ^_^
www.AllanMoncrieffAlarms.com
Hi Thanks for that.
Unfortunatly we are in a very remote location & the only engineers I've found locally just aren't interested. There's no obvious volume control. I've got the manuals but they don't mention internal volumes anywhere, what I'm after is a more fool proof way of knowing the alarm has been switched off.
