Optima 2 Plus
Beia
Hi,
Please help me!!
We have an Optima 2 plus alarm installed at our new house.
We are having some work done and the guys turned off the electric power.
Once they turn it on again, the alarm went on and even with the code it
wouldn't go off.
I have the fuse for the alarm off now, b/c otherwise it won't stop the noise.
What should I do? :hmm:
thank you very much!
Beia
Option 1) With the electricity off it is now running on battery power and if a fairly modern system installed correctly the external bell should stop after 20mins.
Option 2) If it's not fairly modern or was not fitted correctly it will sound until the internal battery runs out which could be several hours.
Option 3) Get the yellow pages out and phone for a local engineer to come out and fix it.
IMO option 3 is really your only option because with option 1 or 2 the alarm is not left in working order merely disconnected with the batteries flat.
The system should be serviced annually with batteries change regularily 2-5 years and annual servicing with a reputable company normally provides 24/7 365 call out support for instances exactly as you have at the moment.
C.
Thank you very much for your help, I think it is a new sytem as the
alarm has stopped but obviously we need to call an engineer out, but how
can we be sure we are dealing with a reputable company that we find in
Yellow Pages? Is there no recognised engineers you could recommend, we
live in London E8?
kind regards
Beia
live in London E8?
kind regards
Beia
if you click the link below there`s a list of everyone in your area
http://www.thesecurityinstaller.co.uk/comm...p?showforum=232
