Door Contact Bypass?
Antman
Hi everyone,
I have an old Bentley F-130 burglar alarm, which was installed when the house was built in 1990. It has been disconnected for many years, but I reconnected it the other day, as I am thinking of moving house - I have both an exit fault and a tamper fault showing on the panel.
Whilst the alarm was disconnected, we had a new PVC front door fitted and the old sensor went with it - which explains the exit fault! The fitter has also installed the new door frame over the ends of the wiring, so I can't get to them to put a new contact in and the wires are routed inside the walls.
So, is there a way of closing / bypassing this circuit inside the panel?
Thanks in advance for any help!
sorry we cannot tell you how to bypass any circuit. but the only advice we can give you is to call out a local engineer who will be able to help..
