kuchars22 Posted August 15, 2008 Posted August 15, 2008 Hi all, I've got the equipment on a workbench prior to installation. Currently I have the 9930 kp, 1 wired PIR and an Elmdene bell wired up to a 9750 panel. On battery kick-start (no mains), it starts up ok albeit reports there is no mains. Now I have connected the 9955 RFX expander and even if the tamper is not open, the KP keeps reporting that there is a tamper on the RFX ("Exp 01 Tamper") upon kick-start and the KP sounder goes off. Is there anything that I am doing wrong? By the way, I can't seem to set the alarm on any level as it keeps saying Mains Fail. Can you not set the alarm on battery only? Thanks
james.wilson Posted August 15, 2008 Posted August 15, 2008 cant help on the rf point but to comply with en regs no you cant set without mains, and in reality you wouldnt want to. But it will be an option you can disable, on a galaxy its called stop set, id assume its similar on the scanny securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
kuchars22 Posted August 15, 2008 Author Posted August 15, 2008 redbull said: cant help on the rf point but to comply with en regs no you cant set without mains, and in reality you wouldnt want to.But it will be an option you can disable, on a galaxy its called stop set, id assume its similar on the scanny Hi thanks for that information, I can't find anything in the install manual, but just found that you can continue to set as described in the user manual. Thanks
kuchars22 Posted August 15, 2008 Author Posted August 15, 2008 kuchars22 said: Hi thanks for that information, I can't find anything in the install manual, but just found that you can continue to set as described in the user manual. Thanks I forgot to also mention about the RFX issue - despite the switch being held down during kick-start, and I'm still getting EXP 01 Tamper, I know the switch is working because if I release the switch the alarm occurs. Thanks
james.wilson Posted August 15, 2008 Posted August 15, 2008 are you sure that the expander is 01, ie is it 00 and 01 is in tamper elsewhere or not fitted? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
kuchars22 Posted August 15, 2008 Author Posted August 15, 2008 redbull said: are you sure that the expander is 01, ie is it 00 and 01 is in tamper elsewhere or not fitted? Hi, it's resolved itself now, not sure how though! Maybe the lid wasn't on properly so the spring wasn't holding the tamper down. Thanks for your help any way guys!
Alarm Protection Posted August 15, 2008 Posted August 15, 2008 It could be that when a tamper has gone of the PIR responds ater a certain amount of time and sends back a tamper restore like the gardtecs. !
kuchars22 Posted August 17, 2008 Author Posted August 17, 2008 Gardtec No 1 said: It could be that when a tamper has gone of the PIR responds ater a certain amount of time and sends back a tamper restore like the gardtecs. Yes you are right, to save battery power
