Panel Location?
CarlG
Hi Guys,
I'm about to prewire for a new alarm and I'm after opinions on the best location for the panel. The choices are: -
1. In the pantry, under the stairs. This has easy access to the consumer unit but it located off the Utility room which also has the back door to the house. The Utility will have a PIR and will not be an entry/exit zone but is that still a bit of a risk?
2. In the loft. Longer wire runs needed and not easy to get to. Is it bad practice to install in the loft though given difficult access for servicing/maintenance etc?
Any views/experience greatly appreciated.
cheers,
Carl
Pantry. So long as the area in which the panel is sited is protected then it's fine. ;)
Not the loft, too hot in summer, too cold in winter.
Thanks guys, appreciate the responses.
I was leaning towards the pantry (not literally) anyway so that looks like the best option.
cheers,
Carl
cheers,
Carl
i'd think so without actually visiting your gaf, and esecially if you park a few 'tinnies' in there (hic!) for meditional thinking and planning needs :whistle:
regs
alan
It's definitely the pantry now after spending all day yesterday running cables! I don't know how the pros can do that for a living cause I'm aching in places I didn't know existed! :wacko:
The medicinal tinnies came in very handy though, good idea Alan.
Thanks again for the advice, got to decide on which kit next but at least I get to sit down for that :)
cheers,
Carl
cheers,
Carl
bet youve never done such a hard days graft in your life by the sounds of it :lol: :lol: :lol:
id either go depending on your knowledge and expertise/experience in the alarm field texecom veritas r8 as that relativley easy to setup especially for begginers (no offence intended if your experienced, or the galaxy panels as they give so much more option available to you. but that would be difficult if your new to alarms or havent used galaxy beore. hope this helps
cheers satsuma
07475071344
Thanks for the info Satsuma, I'll check out those panels. I'd also shortlisted the Scantronics 9651 & 9751 as I'm looking for a hybrid panel so I'll do some comparisons between them (and others I've seen suggested on the forum).
cheers,
Carl
look at texecom for hybrid not the cheapest but good quality
Mark Terry
A.M.I. Security
Covering the Thames Valley
Tel. 01189 775173 24hours
mark.terry@amisecurity.co.uk
